CZLN6":3t5fdyig said:Direct mounting allows for a lower fit and more hood clearance. It also increase flow over a funnel adapter.
CoupeBoy":3jewr0u1 said:He had a funky lever
darwin":25gfwxw1 said:The rebuilt holley---or the 5200 you can also find cheaper if you look around.
kirkallen143":v6r218lj said:made an exact copy of the adapter plate out of 1/8" steel and then brazed this plate to the intake manifold
kirkallen143":3a62prdm said:By the way, does anyone know what I can use to drill thru or grind down nickel? That's the rod they used to weld the other cast head that I have to fill in the low spots for the direct fit 2-barrel. Basically welded a 3/8" steel plate to the original 1-barrel hole, then had it milled flat. Now I am having trouble cutting the weld out. Colbalt, Titanium, Tungsten (works almost) I have tried with little to no success. Any suggestions are welcome.
Kirk ' 73 bronco
