I was going back through many of the post on cams and HP for Crossflows in previous posts from Dynoe250s, XT Falcons, Falcon XF and Tags281. Was a worth while excercise.
In one post found one post from Jan last year that discussed with Addo the use of the 14770 cam. Someone had got a price for a full Crow cam install kit from Repco and it was $780. The kit had special valve stem seals amoung other things that reqiured special machining to fit. Does anyone know why this is needed. Dynoe 250 did you have to use special valve stem seals that required machining with any of your hotter cams.
Im curious because I found out through hard experience how important valve stem seals are when a machinist who ported by 2v head left them off the exhaust thinking it would be ok. It would fill a 4 berth garage full of smoke very quickly until I had them put back on at a cost of about $130. That was with my old cam, my new cam is close to that 14770 duration
The Crow 14770 is a .510 lift 214-224 at 50 and is a terrific cam.
