questions on 250 2V. can you help?
falconcritter
Supporter 2023
Supporter 2021
Supporter 2018
1) do i weld a port divider in 3 and 4 ? 2) what about the wave cast in american and smooth au. head... what do i do about what? 3)
does anybody keep score, stromberg vs holley 350 ? 4) is a high volume oil pump available to buy in usa or au ? 5) do i upgrade the cam ? all of your suggestions will be greatly appreciated :D
1) do i weld a port divider in 3 and 4?
YES
GRIND OFF THE EXCESS TO MAKE THE DIVIDER FIT THE HEAD.
3) does anybody keep score, stromberg vs holley 350?
UNKNOWN, BUT I WOULD GUESS MOST ALL IN THE USA HAVE HOLLEY'S, EITHER THE 350 OR THE 500.
4) is a high volume oil pump available to buy in usa or au?
NO, NOT FOR THE US SIXES. THERE IS ONE MADE FOR THE OZ SIXES, BUT THEY DO NOT FIT THE US BLOCKS. SHAFT AND BOLT PATTERNS ARE DIFFERENT.
5) do i upgrade the cam?
YOU DON'T NEED TO, BUT THE MOTOR WILL RUN STRONGER WITH AN UPGRRADED CAM. IF YOU WANT TO GET THE MAXIMUM ADVANTAGE OF THE ADDITIONAL BREATHING CAPABILITIY OF THE OZ HEAD, ABSOLUTELY UPGRADE.
Thanks for the info AZ ! now i can get a plan of attack. i hope i can do my 6cyl some justice on and off the street!
