Well..... when I first got the carburetor, I pulled it apart. I had another 1940, which I had rebuilt but ran like hell, because some of the screws were stripped on the airhorn and it wouldn't seal, so I changed the SCV and used the new gaskets, and everything sealed good. I did a compression test, all very good. I'll see if I can find the paper and give you direct results, it's still a relatively new motor. It ran good with the autolite 1100 at idle, real good, but it wouldn't accelerate because of the poor pump, and it sputtered and such, and the idle screws would turn themselves in and out because they were poorly seated. I haven't vacuum tested it, because I don't have a gauge. I will try to find one. I will also mess with the idle screws a little more. I didn't clean out the carburetor or anything, and I have no idea how long it'd been sitting. I am planning on rebuilding the carburetor, anyways, since I don't know much about it, and it will be nice to just have it clean. I'm good at it and it's a quick job with these 1940s. The accelerator pump isn't smooth, either, like there's some gnarly grime in it. When I move the throttle lever, the pump moves slooooooooowly, whereas on my other holley it is very fast and right where I like it. =) I will get the carburetor squared away, and it will be nice. I am pretty sure that it's a stuck needle or something... combined with a poor pump, and probably clogged jets and a poor idle setting. I was trying to get some opinions on if it COULD be those things, and since they're possible, I can try to find them. I will definitely update on vacuum findings, and try to find that paper with my compression readings on it. I have done CTs every few months since I got the motor, so I could monitor it. Thanks for your input!
