Well the engine is out and ready to come all the way apart now. I am looking for opinions on what should be done to increase hp.
1.- I have considered flat top pistons but at 17 a pop i don't know if it makes sense to raise the compression ratio just a little by adding them.
2.- I have considered a higher performance cam but I don't want it to be a dog off the line, and I have a c-4 automatic and am not planning on a stall converter, only a shift kit.
3.- I do not think that head work is a cost efficient performance modification and I have heard that a 3 angle valve job will be beat back into a curved form in a short amount of time, is this true.....
I will be installing hookers dual outlet headers on an otherwise stock 1979 200 ci engine. I am planning on a 2 barrel carb on an adapter in the future, and a better flowing air intake. I just wanted you to keep in mind what I already have and wondered what you thought I might do to make it a respectable 6.
Thanks in advance for any ideas.
Hopefully it will be fully assembled and back in 2 weeks
