Howdy Back:
Q- I am at 2500 foot elevation, and I think that lets you use a bit more compression ratio.
A- Yes, 9.2 ot 9.5:1 should be easily manageable given a performance/RV/Mileage cam and cleaning up the chambers.
Q- I don't know about milling a dish in the piston.
A- this would have to be done in a machine shop with a fairly sophosticated, computor controlled milling machine.
A- I think enlarging the head chamber could be done with a carbide bit.
Q- Yes, this is hand work- and tedious. It will require careful cc measuring along the way and in balancing out each chamber so that they all end up the same.
Q- I have a Pertronics in the distributor, it was working OK.
A- The '71 distributor will be compatible with either the Autolite 2100s or Holley 2300s. The Petronix conversion is a good upgrade.
Q- So, if I changed pistons, I still need to deck the block.
A- If your goal is to attain zero deck height to achieve a better quench effect to improve combustion efficiency, then the answer is "Yes". If zero deck height is not your goal, then there is no need to use the 255 V8 pistons either. Just stock 200/250 small dish replacement piston and mill the head to achieve your goal CR. This is a much cheaper, easier alternative, just not as efficient.
Q- What about a good timing chaIn?
A- About the only thing you want to be sure of is that you get a timing set for a '71 250, or earlier. Later sets have the cam advanced for better emission numbers, but less performance. I bought mine from NAPA, but CI may carry them by now. There are, currently, no double roller timing sets available for 250 engines that I am aware of. It is a need.
Q- I have a couple different Autolite carbs, a 500 and a350, electric choke.
A- Either an Autolite 2100, 1.23 or a Holley 350 will work. Both are in the 350 cfm range. I prefer the 2100 for mileage and daily driving as it is a simpler carb with annular discharge venturi boosters. Its only downside is that jets and part are getting harder to find. You will be surprized how close it will be to right on your 250. In any case, an automatic choke is a good idea for economy. Just be sure to set it as lean as possible.
Q- Would it be better to find a different head, than trying to change this one.
A- A '78 and later head will have bigger intake valves, 1.75" to your 1.65", induction hardened seats and a slightly larger volume intake tract- 1,240 to 1,340 cc. IF mileage is you goal none of these issue will matter. Larger valves and greater volume may make a difference for performance, for economy you are more interested in flow velocity. Hardened valve seats can be added to your '71 head.
Q- When was the bigger log made?
A- '69 - '74 = 1,240 cc. '75 - '79 = 1,34 cc. '80 = 1,420 cc. The '80 EOxx casting had some taps and bungs added that added to volume, but may not have helped flow. AKT- while the '71 250
advertized a cr of 9:1, it has the same dimensions as the '72 and later 250 which are advertized at 8:1. What FoMoCo advertizes and what they do are sometimes similar.
Have you given an thought to cam selection for an engine rebuild with "Fuel economy in mind"?
Keep it coming.
