I got the old timing chain and gears off and put on the new gears and chain. However, It looks like the the timing marks/dots are off a little....see picture. Is this okay for a stock motor????You could use a block of wood between one of the crankshaft counter weights and the side of the block to stop the crankshaft from turning then a socket with a ratchet handle or breaker bar should be able the loosen the last bolt in the camshaft center. Good luck
I am way in over my head on this. I need help. How do I begin to fix this. Is this hard to fix. Anyone willing to do a FaceTime call with me on this? Please helpNo thats way to far off try changing your it by lining the dots up correctly and then turn the camshaft to line its key up with the gears keyway. Looks like its off by at least one + teeth, I don’t think it will even run that way if it did it would be running very well. Good luck
I am responding to chad's post -#1
Y R U doing this?
#2
I believe U have lost the timing events and need to degree in the cam.
Plez tell me the totality of what U have done from the begining so I can help get U back to Zero.
This is not a knuckle dragin, neanderthal venture but actually quite scientific and precise. We can get U there but - no questions w/the answer imbeded in it. U must start at the begining w/"xxxx is the problem. What are some reasons for it? What are some of the solutions?" UR starting us a lill in the middle & this can go on 4ever (we've gone 50 posts and pages of entries) & not solve the original problem. Remote diagnosis is difficult, this can simplify it...
Thanks Bubba - I going out now to work on this.....thanks!! This is a challenging project for me but it helps to keep my mind off all the crazy stuff going on in the world. Let freedom ring!Ok start by taking the chain and gears off again. The crankshaft looks like it is in the right position key way at about 2:00 o'clock were it is now. Put the crank gear on and then cam gear without the chain and line up the cam gear timing mark so as to match the crank gear timing Mark turning only the camshaft when the timing marks are lined up notice that the crankshaft key way and the camshaft key way are also pointing straight at each other same as the timing marks do. Now pull off the cam gear again without moving the cam's position slide the crankshaft key back about 1 1/4 inches. Install the chain and cam gear on the crank gear holding up the cam gear to that 2:00 o'clock position with your hand so the timing marks are still both lining up and slide them forward together until it's starting onto the camshaft key and end of the cam then install the cam bolt loosely and continue pushing the gears forward so that the cam gear slides all the way on to the camshaft as well as its key. Tighten up the cam bolt to torque spec, if you didn't move the cam it should be now be correct. Take a picture so we can verify that it's right. Good luck
I am fixing the car up on a low budget. Didn’t want to spend the extra cash for the double roller right nowI know its hindsight but why didn't you use a JP double roller timing chain. They are available from Vintage Inlines.
As Bubba said, your present installation looks fine.
