Dumb question.
I got my power to my gauges again and found out my temp sender is bad. I picked up a new Delco unit last night and just wanted to ask if there were any tricks to installing it.
It looks like you just unscrew the old one, wrap the threads of the new one with some teflon tape and screw it in. Is it that easy or is there a trick?
If I remove the old one, will coolant leak out if I don't partially drain the radiator? How much to I torque down the sender? Should I use anti-sieze?
thanks!
thanks!
