If this
http://fordsix.com/forum/viewtopic.php?t=13847 is what you're referring to, I don't think the topic has been explored nearly enough.
I understand the whys. A centrifugal pump works on the principal that the impeller basically "throws" the fluid outward, away from the axis of rotation. If the opening near the axis connects to the water pump neck, then that will be the input for the pump, regardless of the direction of rotation. The coolant will always be forced outward, so the neck will always see lower pressure, and thus feed the pump. I was just curious if there were any cenriPETAL pumps ("center-seeking") that used pitched vanes to direct flow towards the water pump neck.
I'm thinking about going to all electric accessories, anyway. In my case, that would mean electric water pump, electric fan, and electric fuel pump. The only belt-driven accessory would be the alternator.
I'll probably just gut my old WP and use the gutted neck/housing as input into the electric WP. That way, coolant is being extracted from cylinder #1 and pumped into the radiator, then back to the head at combustion chamber #1. If I want to switch back to the stock flow pattern, I just flip the electric WP around.
With the Xflow head on a US block, 3/4 of the coolant passages on cylinders #2-5 are blocked anyway, so there wouldn't be much exchange of coolant going on between the block and head in that area, right? For the most part, it would seem that the coolant would flow the length of the head, and then the length of the block, or vice versa. Is this correct?
(For those who don't know, I'm planning on mating a US250 block to a Crossflow head)
