Its awfully easy to screw up an 8 grand engine with forged pistons with the wrong ring sizes. My current engineer for XEC is the same one who told my mate Blair that just a few thou error with a set of forged pistons, and you can bin a thinwall engine block with piston rattle. Our 375 hp engine that gave great mpg and performance had forged piston slap at 1500 rpm, and we had to rebiuld the whole engine again.
Also happened to Ford many times during the 90's as plateau honing was perfected to suit the new piston technology. And it wasn't because Ford didn't do there homework.
Regards going to a tighter bore for forged engines, thats certainly true of the first 1979 TRW 2.3 Lima Turbo in the Mustang Turbo, the forged piston 5.0 GT engine in the 80's and later 90's versions, and then every forged piston Ford since.
But 'In the begining' (1968 to when the Federal Emission tests 50 000 mile durablity run caused problems passing TRW pistoned small and big block v8s), the wildest versions of the 302 and 350 Chev and most aftermarket TRW pistons before that had really wide clearances, they were always piston rattlers untill Ford practically commericalised forged pistons when the Pinto 2000 Sierra and 2300 Merkur/SVO Turbo came out.They were still cold engine rattlers, but that was becasue they were rough 4 cyl engines.
The 1992 5.0 liter with TRW's was one of the smoothest forged piston engines around, to this day people attempt to copy that combination.
I saw the results of running stock 4.030 bore and stock Ford factory clearances for cast pistons, then at the last minute, we got 351 4V Boss forged pistons, and scored the cyinders of my mates NASCAR block back in 1988. The rule is, find your combo, then do everything the piston maker says regards rings and bore RA. The first engine forged piston engine scored the bore, and had to be reuiolt with a whole new block.
