Saving a '74 E100
Top Poster
Staff member
Supporter 2021
Supporter 2019
REDLINE 10K
I always wanted to try out one of the HD manifolds on my old 65 F350 they were like hens teeth back then, as most of those trucks were still fairly new and being used for work. The HD is also a quick way to do a simple U bend (more like a 45 degree) Turbo install too. Wow that's a lot of raining going on! Good luck
BigBlue94
1K+
Supporter 2021
Supporter 2019
This particular HD manifold was off an F6/700 water truck IIRC. Im gonna have to source an intake, as I sent the original one off to old28racer, and I would rather have a bigger carb anyways. And ill have to find a valve cover in the JY. The 74 one is on my bronco. Lol as I say that i look up to see one I rusted on purpose and hung above my lathe room door!
I dont believe there is any room in the doghouse for a turbo! I do have a couple bigger diesel turbo's on the shelf: one from a 7.3 powerstroke and one off an international DT466.
But im just gonna keep things simple. 9:1 compression max with a mild cam, worked over head, 3" exhaust, and a cold air intake of some sort. Efficiency and reliability would be key.
Top Poster
Staff member
Supporter 2021
Supporter 2019
REDLINE 10K
That sounds like a great plan taking shape simple is always a good way to go when building a rig to travel long distances from home. There was a site member who was building a Turbo system on a Van by mounting it down low and towards the front passenger side don't remember if he ever got it finished though.
BigBlue94
1K+
Supporter 2021
Supporter 2019
Finally made it over to the neighbors back woods to check out the body on the ol 74. Its kinda rough. Rear passenger bottom corner is crunched. Entire drivers rocker is toast. Rear doors have rot on the bottoms. Driver side wall has some rust spots but not holes yet. Passenger side is much better on all accounts. Floor is covered in crap but solid in the spots in checked. Even shiney white in spots.
I need to look again but I think I can get new panels for the bad spots but the driver side rocker may be an issue.
Its not buried in the dirt like i thought, so the frame should be pretty solid. Need to pull it out and get a better look.
Hi Everyone,
I am looking for a source for a windshield. I have 3 of these vans but I am going to part out my 1969 to repair the 1971 e100 and the 1974 e300. 2 of the vans have broken windshields. I will do a thread at the beginning of the year to introduce myself and the vans properly. Thanks.
BigBlue94
1K+
Supporter 2021
Supporter 2019
Hi Everyone,
Howdy Jay, im lucky all the glass in mine is in good shape except one missing window. Parts seem to be ultra scarce for these.
Idk where you are located but there are a couple junkyards in KS that may have a windshield: they have massive inventories. One is Easy Jack's near Junction City. The other is in Great Bend, called Nobody Else's auto salvage. Call for service: (620) 793-3557. Both places are stacked with autos from the 1900s through the 80s and inventory is always changing.
