We've had quite a warm up. To the point I could finally get through the snowdrift to where my old SBC FI heads were stored. I've got a couple pairs of the "camel" or "double hump" early 60's 1.94 fuel injection heads. They used to perform quite well on 8,000 rpm+ flame throwers.
The thing I found interesting was that the exhaust valves appear to be in the vicinity of 1.45". Definitely under 1.5". Those heads were great for small block (283 - 327) engines built for hive rev HP. Does the difference have to do with the short stroke nature of SBC's?
'Seems to support Iskederian's stance on the "modern myth" of dual pattern cams (being unnecessary for most) and raises an even more relevant concern for some of us. As DP cams are intended to increase relative exhaust duration, and larger (exhaust) valves/longer exhaust duration have a "low end torque" stealing effect, just how big of an exhaust valve is really needed for the I-6? I know - 'depends on your application"...
I realize it's a balancing game, but when I held a 1.94 up to the (smaller)stock 300 intake valve, and then did the same with the exhausts (and found the stock 300 exhaust valve to be the larger), it made me stop and ponder...
Might a smaller exhaust valve be beneficial to at least some of us?
broncr
broncr
