pmuller9":t3bp8bmx said:
The SAE standard for the advertised duration is calculated on the .006" lobe lift.
Some will argue that some cam companies will use a lesser lobe lift to increase the advertised duration but all you can do is use what is given
Using the .006" lobe lift number gives that value using the many different DCR calculators available online.
This is or was done quite a bit, listing advertised anywhere from 004", .006", .012", .020"
The company makes the cam seem larger, smaller, more or less aggressive. Very common with marketers of the generic "white box" cams that are made by CMC and sold under many different brand names. It was a big reason Harvey Crane pushed the .050" duration numbers. Of course there is a lot more than advertised or .050" to a lift curve and how the cam performs.
Then there is Harley with .053" lift numbers....
