some progres pic
alu pully wheels are coming up , almost ready , these designs wil bolt on over an orginal single pully balancer 3 bolt , also got it for the 4 bolt setup .
they wil look about these style al the alu wheels. belt driven !!
also in progres my turbo setup . blow treu with solex carbs , for dual fuel lpg and gasoline !
this site is for the loghead , the other site is also commoing from 1 turbo outlet tube , to 2 inlet tubes for the solex carbs with the lpg adapter [ dual ] between it !
If you are using this pulley for the crankshaft, I do not see any vibration damper rubber between the hub & the pulley.
If this pulley has no means of vibration dampning, it is very pretty but useless without vibration damping charactisics.
I have seen broken crankshafts from engines run without a damper. William
look ad pic nr 2 !! you see an orginal balancer wheel !!!
like i did told . it wil bolt on OVER the orginal balancer wheel !!!!
If this pulley has no means of vibration dampning, it is very pretty but useless without vibration damping charactisics......
Useless? Didn't the 144/170 from 1961 have a solid pulley? No vibration damper on those? It only had 4 main bearings.
Now I see what you are saying. I'm sure you are planing a mark on the bolt on pulley for a TDC timing reference.
The quality of the pulley looks very professional, but what is the cost??
Mike @ FSPP used to offer a dual pulley dampner, but now are out of stock. Mike correct me if this just a temporay situation.
The bolt on deal would be ok as long as you can retain vibration torsional dampner quality. William
