finnstanger
My stock 200 started to run unevenly (sharp cuts) under even load. Idling was normal and I didn't feel any cuts when accelerating or running at >45mph.
I checked the spark plugs and found that they were light gray coloured,almost white. There was also quite a lot of white residue in them and in some plugs the air cap had filled and reduced.
I replaced NGKs with Motorcraft BSF82Cs and it started to run normally.
Is too lean fuel mixture causing this ?
I'm using 98 octane gasoline(91 super?) with Kalium based lead substitute.
