I had this problem before I left 4 months ago and now that I'm back I'd really like to figure it out.
The problem is this:
I am driving straight about 10mph and then I push the pedal a little further like to get to 20 mph and the engine dies for a quick second and then comes back alive and I can continue on to 20 mph. Its not dying slowly either, its a real quick death. Almost as if its switching to some other electrical connection or switching to another fuel source then it runs fine. I have noticed some "surging" when I'm at higher speeds, just barely noticeable but It runs "weird". It also does the same thing on left hand turns but not right hand turns, I posted the other stuff on top because its probably easier to figure out. I hope this describes it well.
I've changed the following:
Electrical system - Dizzy, spark plugs, and wires still using Pertronix coil.
Fuel system - Fuel pump, fuel hoses, filter and added a psi gauge to check pressure.
I've been searching for a vacuum leak by spraying some carb cleaner around areas where I think it could be and found nothing. Today I put playdoh all over those areas to try to create a seal and nothing changed.
I've played with my timing over and over again.
The carb is spraying fuel its brand new and worked fine before I rebuilt the engine.
Any ideas?
Side note: the engine runs fine (As far as i can tell) just sitting in the drive way idling or even when I rev it up. Seems like its only under a load on the road.
Any ideas?
