Does anyone know if anyone else offers anything like this and and how it runs or if this is a good deal and does this give a 200 I6 anymore power.This is the only Rebuild Kit I could find.
Or can you buy the peices seperate cheaper?
This is on cliff.performance.
picture:
http://i81.photobucket.com/albums/j216/ ... g20300.jpg
Here is your Super Rebuild Kit to help you get the big torque numbers out of your Ford 200-250 engine. Kit includes; Alumimum alloy Pistons w/pins .030 or .060 overbore using chrome rings. Clevitte main and Rod bearings, .010 under, std cam beaings, Clifford 264 cam, hi-lift springs, retainers, valve locks, hardened pushrods, complete gasket set, double roller timing set, melling oil pump. If you order our Blueprinted cylinder head, the rebuild kit price will drop to $818.00. You springs, retainers and valve locks will be installed on your new head.
picture:
