I'm seeing a lot of mention of swapping Holley 350cfm to 500cfm 2bbl carbs. Different folks think different things about the pro's and con's. Here's another thought that may be a fresh idea, or may be old news:
Has anyone given thought to adapting a Holley 480cfm 4bbl with vaccum secondaries? It would require fabrication to mount the 4bbl, but might be worthwhile.
Based on my search for a bigger carb on my old 302-equipped Falcon (before they lifted the CA smog restrictions on the '69's) it seemed to me that the Holley 500cfm 2bbl had two huge mains and no secondary. I was advised that it would be a Bad Idea<tm> to do this swap since the carb would feed way too much fuel at low RPM. The upper end performance gains would be good, but at the expense of low end power and fuel economy.
Enter the 4bbl- The mains feed the right amount of fuel for economy driving, and the secondaries deliver that added punch when opening it up. I'd think it would work the same on the Inlines. The 480cfm should deliver plenty of flow for those engines that need it.
Am I totally daffed? Or is the fabrication work just too much of a pain in the butt to worry about trying?
Relatively uneducated guess, but it's food for thought.
--mikey
--mikey
