The switch over from the earlier G series engine to the later H series was made as a running change during the 1947 model year. The cam gear was changed at that time by reversing the angle of the 48 teeth. The attachment of the gear to the cam continued to be by four bolts. Sometime later, the attachment was changed to press on and the bolts were no longer used. Its my understanding that the earlier bolt on H gear can be used with the later cams by pressing on the matching flange if you should want to. There are changes to the chamfer where the nose of the cam meets the front bearing journal, some are fileted, some are square and some are undercut. Do not use the square cut gear on the fileted cam, it can cause interference. Some of the very early H cams have a different number of cam and oil pump drive gear teeth than the later ones which have 10 teeth. There is a post somewhere in this topic concerning this and the early cams require an oil pump drive gear that is bronze and hard to find. Use only aluminum cam gears. Be aware they came in several oversizes, I think .006 and .012 to take up wear in the crank gear. I saw those gears on ebay, they were fiber, not good!!!
