Here's the
CarterYH doc.
The Carter doesn't go lean at the top end, it goes bog rich. The venturi is too small for the airflow. All that top end created vacuum's gotta suck something, and that something is gas. But, the top end over-rich bog-out has saved countless corvair owners from melting down their engines. First by running so rich the engine bogs, and second all that extra fuel cools down the intake charge going into the cylinder. Whether this was a designed in feature or just a happy coincidence, Zora only knows.
For a 200, the 40mm weber dcoe will let you run WOT without going too rich, and give you good throttle response over the entire powerband, with many tuning options. The carter is about as sophisticated as a beer can full of gas with a couple holes punched into it, in comparison.
The rajay unit, although listed as three seperate turbos, is in reality, one center section (one part number) using two different compressors, and three different exhaust housings. Each impeller/compressor is matched to it's particular housing, but you can mix and match the compressor sides and exhaust sides as you like. The two compressors are the 150 and 180, and the three exhaust housings are the 62-63 150, the 64 150, and the 65-66 180. The only difference between the 62-63 and the 64 housing is the exhaust flange.
As panic said, the hot setup is an "E" flow impeller/housing and the stock 180 exhaust housing. The E flow is not a stock piece, but a modern and very efficient impeller design in a modified stock housing.
This is all moot as your turbo is in hand. As fordonatic Dave Williams says "Free is a virtue overcoming many faults". No faults with what you have though.
The stock 150 can put out up to 10 lbs of top-end boost on a corvair, probably even more, and sooner, on the bigger engine. So a pop-off/wastegate routed back to the upstream side of the turbo is probably a good idea (can't be venting compressed A/F mixture into the engine compartment, ha ha!). Did I mention water injection?
Rick(wrench)
