Hi, I am looking for some pictures to show the routing of the vac line from the dizzy to the carb(Autolite 1100). The car is a 63 Falcon and the engine is the 170. I am making my own line and would like to be close in the routing. Thanks in advance... :thanks:
Bubba, thanks that's just what I was looking for! One question, does the line come out of the dizzy and do a 180 turn towards the block? Thanks again...
It dose like a 90 a little 180 loop than a 90 etc get the idea? the loop is so you can adjust the timing of distrib. it than goes around front of V.C. has a clip for fuel line and it than turn the coner of V.C. etc. back to carb there are a lot of bends in it but they are all wide sweps not tight bends.
I don't want to take any fun away, but Mustangs Unlimited sells a pre-formed vacuum advance line for the six for $11. Even if you want to bend it yourself, their website has a nice illustration that will give you some details:
Eaglo, thanks for the info . I have some of the right size tubing, end fittings, and a bender lying around so I thought I would give it a try. But as some of my projects go it's nice to have a back up. I may order that in the end. Thanks again.
