I66coupe
I need to replace the valve stem seals on my '66 200. I have not yet removed the valve cover so I have not yet even seen what they look like. I have never done this before. I also don't have a service manual.
So, how difficult will this be? Any tips? Seems to me this should be pretty straight forward. Remove the rocker, compressed air into the cylinder (to hold the valve up), valve spring compressor, remove the spring, remove the seal, install new seal, put the vale spring back in, done. Right?
Need to know how to reset the rocker for proper clearance. Any advice, links, would be appreciated.
