SixFoFalcon
I'm getting together a list of the valvetrain components I plan on using when I build the US250-Crossflow hybrid. Here are my preliminary selections:
*Crow Cams camshaft part #14776 or 14892 (hot but streetable)
*Speed Pro lifters, Summit catalog part #SLP-HT-900
*Comp Cams Magnum Steel Roller Tip Rockers, 1.72 ratio, Summit catalog part #CCA-1411-1
I will be using stock valves. The pushrods will be OEM parts for the GM 3.8L (non-roller) as spec'ed out on the "200 Crossflow" page.
I also considered Rhoads lifters (Summit catalog part #RHL-RL9008). They supposedly decrease valve lift at low rpms for better low-end power and overall economy. The problem is, when I do a clearance test by hand-turning the crank, I won't be getting full lift on the valves. I'd have to crank the engine at 2000rpms or so to see full valve lift.
Also, I'm not sure what to do about valve springs and retainers, yet. Crow Cams sells the "parts kit," but that includes a timing set, which I don't know if I can use on the US200 or US250. Any ideas?
Also, does anyone know of an online source for Crow Cams products, so I can price out the cams and other stuff? So far, I'll I've been able to find is the Crow Cams catalog, which has no prices.
