vibration
200-6-coupe when i bought car all suspension was orig. replaced all front end parts, from 40 m.p.h. developed a vibration installed pentronix set timing , still vibration,new harmonic balancer , rad. started leaking, replaced rad. water pump, no change, new balanced drive shaft w/ new uni. joints no change, also new tires, brakes front end alined ,no change installed new motor mounts , trans mount, rear springs guess what, vibration gone. want to thank everybody who helped,esp. william w/ pentronix. hope this helps someone else. will be in touch, mike
Howdy Back Mike:
I was down that road too. Finall began to isolate each and every part. It turned out to be the front driveshaft yoke.
I still trying to figure out what vibration was eliminated by replacing your engine & trans mounts and the rear springs? What caused the vibration and what fixed it? Or did the new mounts just mask it?
Any way, It's goo that the vib is gone.
