Walker Products Autolite/Motorcraft 2100 15369D Instruction Sheet
old28racer
I just got a Walker Products 15369D carb kit & it did not have an instruction sheet in the box. Kit is for a 2100 Autolite carb. I have looked all over their Web Site and can not fine any rebuild instruction sheets. Anyone know how I might find one today? Would like to get started but may have to call them on Monday. Thanks
Top Poster
Staff member
Supporter 2021
Supporter 2019
REDLINE 10K
This is the link to the Autolite / Motocraft 2100 carb rebuild "Instruction Sheet's" though it isn't the "Walker Products" per say it's still the common instruction sheats that used in all carb rebuild kits from the many brands of rebuild kits. It covers all these Models 1959 & 60 Edsel's, 1958 to 1974 Ford & Mercury cars plus 1958 to 1974 Ford Trucks and more. Ten pages worth so you should be able to find all the assembly and set up info you could ever need. Best of luck on your carb rebuild (y)
Autolite / Motorcraft 2100 1958 to 1974
https://www.carburetor-parts.com/assets ... /K4008.pdf
old28racer
bubba22349 -- Thanks for the reply, I saw that sheet on Mikes site and will use it if I can't find one for Walker Products. Only thing different was the scale to set float level.
Update, late Monday 6/22/2020 -- Got the new kit mounted in the 2100 carb, all went well and it should work fine. May have to reset float level later, does 7/16 down from top edge to top of float tail end sound right?
Top Poster
Staff member
Supporter 2021
Supporter 2019
REDLINE 10K
Hi old28racer, yes that should be in the ball park. :nod:
old28racer
bubba -- Thanks, it will be a few months before I get the modified 240/300 intake installed in my F250 300 4.9L that I am going to try my Holley 2300 & this Autolite 2100 on.
Top Poster
Staff member
Supporter 2021
Supporter 2019
REDLINE 10K
Ok old28racer, will be looking forward to hearing how this intake carb experiment works out for you. :nod: (y)
