what do i need to put a holley weber 5200 on a 200
stang65
Active member
hi
i want to put a holley weber 5200 on my 200
with original head
which adapter can i use
can i use the adapter from trans dapt??
which other modifications are required?
pics welcome;-)
thanks marcus
Transdapt has one or you can buy one from Langdon Stovebolt. I believe Mike at ClassicInlines also carries them.
You'll likely need to do some modifying to connect your existing throttle linkage to the carb. I'm not sure about that one - someone will need to chime in.
