As much as I seem to read I still cant make sense of the different turbo model numbers
I have a turbo I beleive to be off a Mitsubishi with the following numbers
On the Turbine side ...
080D2
48168-13200
On the Compressor side
49168-01300
MHI TC05 12A 1F
The measurements off the turbo are as follows
Turbine inlet 44mm
Turbine outlet 48mm
Compressor inlet 44 mm
Compressor out 32mm
This is with the intention of mating to a 250
I wonder wether I t will have enough flow on the turbine side as the inlet diameter seems small
The Turbine inlet reduces from the flange at 44mm to approx 30 mmnext to the wheel itself
I already have a Holley Blue fuel pump Malpassi regulator 350 holley but cannot figure the turbo
Help me please........
080D2
48168-13200
49168-01300
MHI TC05 12A 1F
Turbine inlet 44mm
Turbine outlet 48mm
Compressor out 32mm
