TeamNeptune
Active member
This is what I have done so far. What if anything is not correct for my usage. What should be considered for improvements in performance.
I have a 1978 ford Ranger 4x4 with 35" tires. T18 trannie. I primarily use it to pull my boat. It has a reconditioned block that is stock as far as I know.
Here is the list of modifications I have done.
Edelbrock 500 carb. mechanical sec. re-jetted secondary's to match the primaries.
Clifford 4bbl. intake
Comp. cam 268
early 60's 240 head tapped for 7/16 rocker studs with stock rockers, (intake 1.875) (exhaust 1.60) performance valves. No porting.
efi exhaust manifolds.
I am currently installing 4.11 differential gears to offset the over sized tires. It will take a while for me to recover from this expense.
Tires I know are costing me but I just like the way they look and it will se some 4 wheeling during hunting season.
Cam ??.. Larry says it is all wrong and should replace with his. With the 4.11's I will be hauling on the highway at around 2700 rpm and I wanted the engine to have a slight lope . I like the sound.
The only problem that I was having and keep in mind this was before the gear swap is staying up to speed on the highway.
long hills would cause my speed to drop off from 70mph to 55mph frequently.
Comp. cam 268
