Which Vac outlet on my Carb for my DSII
choppermike
I put a Carter YF (from a 79 Granada 250) on my 65 stang 200. I am about to convert to DS II. My question- there is a vac outlet on the drivers side of the carb and two on the passenger side. Can anyone tell me which one it might be?
Thanks, Thats interesting. I have plugged the ones on the carb as of now and its running great. (Unilite Mech. Advance) I plan on installing my power brake booster in about a month. Do you think I may have to get a vac canister or will the manifold port handle all of my vac needs?
My stock 6 has a brass block with 3 vacuum ports at the side of the manifold. I have been told that this is the stock configuration. Two of these are blocked (with a rubber tube and plug). It seems to me that there is enough vacuum to go around from this point, even for power brakes.
