Wont Idle in Gear!! Help!
well ive been driving me stang, because my daily beater broke, and today on the way to get my check it started doing not wanting to idle in gear, it'll idle for a min or two then the idle gets rough and it pops and dies if i start it again out of gear itll idle at about 1k and itll pop every once in a while. this just started today, going to look at it tommorow in depth..
geee its a good thing i got my datsun running decent today. mabey the stangs jealous... hmmm.....
(edit) oops its a 200ci 80 faimont motor with carter carb non emistion C4 slush Box, duraspark 2 and msd box and coil.
Well I found out what it was... the carb screws around the throttle plate where so loose that when i took a corner the carb would lift away from the throttle plate and cause a air leak... last time i get a remaned carb without checking the screws..... :fume:
