Looking in library agian recently and Aussie Motor mag 1979 did a dynoe comparison with the 253 V8 in a Commodore against the XD Falcon with the carb 250 Alloy Crossflow.
The Cross flow peak power came in at 3500rpm at 72 kw to rear. 253 was about 73 but at 4000rpm and considerbly less torque.
Question (Execute?). If this was the kw of Crossflow to rear in standard form with the emission control ect Im wanting a "rough estimate" of what it would be with it off and cam (mild) carb and extraction upgrade. If I do this I would like to get at least 95kw to rear and maintain efficiency of engine.
I am fairly certain from other comparisons Ive done that my 250 2V with the cam and carb and dizzy changes is about 95kw to rear and it has good economy on open road.
Over time I want to prep another engine just trying to work out if it its worth going to crossflow. I am guessing that with similar or same changes might end up with same power maybe bit more and better economy as well.
This is what Ive worked out emission off 15%. Minimum 25% with cam, carb and extraction changes. Equals 40% increase. I presume this would not be difficult and would give more than 95 kw to rear. Am I off the mark or is this about right.
