Best gasket/sealant procedure for cast valve cover
Eric Rose
Post #1 by Eric Rose » Sun May 14, 2017 10:04 pm
Hey all
I got a cast aluminum valve cover from Vintage Inlines recently. Beautiful piece. Now I'm looking at how to seal it. My previous installations of stamped steel covers have always leaked. I use the nice re-usable rubber gaskets on engines that I can get them for but it seems like cork is the only option for the ford six. I'm also using studs instead of bolts so it'll line up easier.
I've seen people say spray the cover side with 3m spray adhesive and tack it on to the cover and that's all that needed. No selant between the gasket and the cylinder head. I don't know how to feel about that?
Also seen people say this method works: Thin layer of RTV between cover and gasket. snug the bolts and leave it on a few hours til it's dry. Then do the a bead between the gasket and head and leave it just snug for a few hours, then torque it when the rtv has dried.
Also been hearing how permatex #2 is better than RTV. And still others say just put cork gaskets on dry. :shock:
It's one of those questions where you get 5 different answer and none of them are "wrong". But every application is different so if anyone has a method that has been proven to work with the ford six engines I'm all ears.
I got 350 heads on a 305 engine. I get 10 miles to the gallon, I ain't got no good intentions.
- Mike Cooley, aka the Stroker Ace.
rbohm
Assistant Admin
Re: Best gasket/sealant procedure for cast valve cover
Post #2 by rbohm » Sun May 14, 2017 10:51 pm
i prefer to glue the gasket, regardless of whether it is cork or rubber, to the valve cover with 3M weather strip adhesive, and let it set before installing the valve cover. i like to use valve cover bolts to hold the gasket in place while the adhesive sets up to make sure the bolt holes line up properly in the end.
i have never had a leak using that procedure, except once early on when i over torqued the valve cover bolts and split the cork gasket i was using at the time.
64 falcon
66 mustang
05 grand marquis
transient nodes of thought
of invention
B RON CO
Post #3 by B RON CO » Mon May 15, 2017 6:57 pm
Hi, I feel a lot of guys over tighten the bolts and that causes their problems. Just go gently snug and see how that turns out. Good luck
1966 Ford Mustang - 289 V8
Post #4 by bubba22349 » Tue May 16, 2017 11:07 am
X3 I also glue the gasket to the valve cover, then you can usually remove it once or twice if needed without damaging it. Most problems that people have with gaskets for valve covers and oil pans is from over tightening the bolts and damaging the gasket or pushing it out. Good luck :nod:
woodbutcher
Post #5 by woodbutcher » Tue May 16, 2017 2:12 pm
:hmmm: RE:Over tightening .The easiest way that I have found to cure that is to get some studs and Nylock type nuts and use that method to do the install.Lightly snug the nuts,and forget them.
The studs that I have used have Allen type ends,which make it very easy to install them.And remove them if necessary.
Good luck.Have fun.Be safe.
Leo
Otto von Bismarck
wsa111
FSP Moderator
Post #6 by wsa111 » Tue May 16, 2017 3:42 pm
Leo, I like your stud method. X4 on gluing rubber gasket to cover. The best of both worlds.
67 mustang,C-4, with mod. 80 hd, custom 500 cfm carb with annular boosters, hooker headers, dual exh.-X pipe, flowmaster mufflers, duraspark II dist. with MSD-6AL. Engine 205" .030" over with offset ground crank & 1.65 roller rockers. 9.5 comp., Isky 262 cam.
Gene Fiore
RC Moderator
Post #7 by Gene Fiore » Tue May 16, 2017 5:56 pm
I'll chime in on this as well. The rubber valve cover gaskets are available for the ford six. I have one on mine with the classic inlines aluminum cover. I also glue the gasket to the cover( I use ultra grey rtv ) and, as others have said, do not overtighten the bolts. Never any sealer between the gasket and the head. I have a solid lifter cam and I have that valve cover off regularly to adjust the valves and it never leaks...ever. :wink:
1971 Maverick, 250I6, crank knife-edged, Clay Smith 278 solid cam, .040 over 255 V8 pistons, 10.5 to 1, Custom 500 Holley 2V direct mount, 1.6 rockers, mild port/polish, Hooker header, DUI dizzy, C-4 w/2800 stall, 8" 3.55 det locker
Best ET 1/4 mile: 14.92 at 89.61 mph on 1/12/2013
My Classic Inlines Photo Page
ledslinger29
Post #8 by ledslinger29 » Wed May 17, 2017 8:48 am
Does anyone have a source for the rubber valve cover gasket?
68 Bronco Halfcab 170 wallered out .060 over, oversized valves, zero decked, 9:1 SCR, Autolite 1100 w/ Loadomatic/Pertronix, Schneider 248/56H cam
woodbutcher
Post #9 by woodbutcher » Wed May 17, 2017 11:49 am
:D Hi Bill.Yeah,that stud setup is great.Have been using that for about 50 years.That was before
Nylocks as IIRC.Started using Nylocks when they first came out.Have`nt looked back.
Leo
Otto von Bismarck
wsa111
FSP Moderator
Post #10 by wsa111 » Wed May 17, 2017 3:35 pm
ledslinger29 wrote:Does anyone have a source for the rubber valve cover gasket?
Advance Auto Parts has the Felpro brand, make sure you get the rubber one as they also offer cork.
wsa111
FSP Moderator
Post #11 by wsa111 » Wed May 17, 2017 3:37 pm
woodbutcher wrote::hmmm: RE:Over tightening .The easiest way that I have found to cure that is to get some studs and Nylock type nuts and use that method to do the install.Lightly snug the nuts,and forget them.
Leo
Leo where did you purchase the studs???
woodbutcher
Post #12 by woodbutcher » Wed May 17, 2017 5:25 pm
:hmmm: Hmmmmmmmmmmmm any number of places.Such as the local mine supply,Ace hardware,the old NAPA store in Fl where I grew up.Lowes or any big box store should have them also.Any decent hardware store.AND,I bet MacMaster/Carr too.
Leo
Otto von Bismarck
cr_bobcat
Post #13 by cr_bobcat » Wed May 17, 2017 9:48 pm
I'm running studs too. I got them so many years ago that I forgot where I sourced them from though. I have wide washers (triangle shaped) as well, to help even out the pressure.
woodbutcher
Post #14 by woodbutcher » Thu May 18, 2017 9:38 am
:bang: Also forgot to mention the OLD Sears stores in the hardware dept.Also machine shops of the time were a good source of odd ball stuff.Might also try aircraft and marine supply outlets.
Leo
Otto von Bismarck
Eric Rose
Post #15 by Eric Rose » Thu May 18, 2017 10:21 am
I couldn't find the studs anywhere local. Checked all the brick & mortar places like parts stores, Tractor Supply, hardware stores, etc and couldn't find anything that would work. I looked them up on McMaster Carr but with the cost of the studs and shipping it was cheaper just to go with ARP on Ebay. Found a set at a good price with free shipping.
There's a place in my hometown that carries all this stuff cheap, but it's 100 miles away.
cr_bobcat
Post #16 by cr_bobcat » Fri May 19, 2017 8:50 am
Just hit up ebay with "Ford 200 valve cover stud". You'll have options.
78 granada
Post #17 by 78 granada » Mon May 22, 2017 3:57 pm
Felpro VS 12692 R is the rubber gasket.
Eric Rose
Post #18 by Eric Rose » Wed May 31, 2017 4:14 pm
So I ordered ARP studs, it turns out they wouldn't work because the clearance on the sides where it's indented is very tight, too tight for a wrench or a socket for the nut. So I went with T-bolts. I would think a socket head cap screw that takes an allen key would also work.
Post #19 by bubba22349 » Wed May 31, 2017 8:48 pm
Eric Rose wrote:So I ordered ARP studs, it turns out they wouldn't work because the clearance on the sides where it's indented is very tight, too tight for a wrench or a socket for the nut. So I went with T-bolts. I would think a socket head cap screw that takes an allen key would also work.
Yes that's exactly why Ford used a special made (smaller head size than normal) valve cover bolt. Glad you found a workable solution. Good luck :thumbup: :nod:
chad
Post #20 by chad » Wed May 31, 2017 9:50 pm
so on the steel VC the tabs that go under the nuts (non-OEM used as 'protecters' to reduce bending of VC) R a good idea?
(Not needed on the cast - as in this application).
For here I'd just glue the feldpro to the VC, use a T handled allen for quarter twenty sucker headed bolts?
Chad - '70 LUEB on '77 frame (i.e. PS, D44, trapezoidal BB 9", 4.11), 250, NV 3550 & DSII to B transplanted, "T" D20/PTO, 2" SL, 1" BL, 4 discs, 33"X15", etc. Seeking: Hydraulic gear motor for Koenig pto. chrlsful@aol.com (413) 259-1749
Eric Rose
Post #21 by Eric Rose » Tue Jun 06, 2017 10:43 am
The Vintage Inlines air cleaner adapter for the YF moves the air cleaner off center from the YF's carb stud so I need an offset air cleaner stud now. the lid's tied on with a wire for now.
Users browsing this forum: No registered users and 10 guests
