Flat tappet oil questions
falcon_master
Post #1 by falcon_master » Mon Mar 12, 2018 5:16 pm
Hi everyone it's been awhile. I've been busy working on a project truck for my dad a 1978 dodge lil red express. It's ridiculous how much it needs. No I'm replace the friggin water pump cause the other rusted through ahhhhhhhh! But I finally got back to my falcon and I was wondering I know these have fall tappet came and modern oil is low on zddp. So is it ok if I just buy an over the counter Additive or is that not good enough thanks everyone
High School AFJROTC cadet and car enthusiast. Likes all things ford and engines of any company. 64 falcon 2dr sedan with 144 six and "3 on the tree" column shift manual transmission. Still in make it move stage.
B RON CO
Re: Flat tappet oil questions
Post #2 by B RON CO » Mon Mar 12, 2018 6:35 pm
Hi, I've used Castrol GTX 10w 40 for many years and never used an additive. The cam was changed at the last rebuild over 25 years ago. If I was to build a new engine or just change the cam and lifters I would use an engine builder additive. I think after the initial break in period regular quality oil should be good. The oil has changed for environmental reasons. Good luck
1966 Ford Mustang - 289 V8
StarDiero75
Post #3 by StarDiero75 » Mon Mar 12, 2018 9:21 pm
falcon_master wrote:Hi everyone it's been awhile. I've been busy working on a project truck for my dad a 1978 dodge lil red express. It's ridiculous how much it needs. No I'm replace the friggin water pump cause the other rusted through ahhhhhhhh! But I finally got back to my falcon and I was wondering I know these have fall tappet came and modern oil is low on zddp. So is it ok if I just buy an over the counter Additive or is that not good enough thanks everyone
I use 10w-30 Valvoline VR1 racing oil and ill probably go to 10w-40 next oil change. The racing oil has a good amount of zinc in it. Some people are lucky and it doesnt wear the cam, others not so. I take no chances on my baby so i put the nice stuff in it. I have crappy basic stuff in my Stude but thats because ive only run it twice in a year for no more than 40 seconds (no water pump and no time to fix it). If it drove, id put the nice stuff in it too.
The additive doesnt mix well with the oil and separates usually, not causing it to do what its supposed to do.
The VR1 stuff is about $7 a bottle or $35 for a pack of 6 on amazon.
Good luck,
Ryan
--1965 stock 200 Ranchero w/ 3.03 column shift, 8" rear 2.8 (Yes I know the gearing sucks), weber 32/36, CRT Performance HEI.
--1961 Studebaker Lark VI, OHV 170 l6 in the process of being resurrected.
wsa111
FSP Moderator
Post #4 by wsa111 » Mon Mar 12, 2018 10:07 pm
Brad-Penn Racing oil 10W-30. I contains all the additives, but detergent for street driving that the VR1 does not have??
It is a semi-synthetic blend.
67 mustang,C-4, with mod. 80 hd, custom 500 cfm carb with annular boosters, hooker headers, dual exh.-X pipe, flowmaster mufflers, duraspark II dist. with MSD-6AL. Engine 205" .030" over with offset ground crank & 1.65 roller rockers. 9.5 comp., Isky 262 cam.
chero1369
Post #5 by chero1369 » Tue Mar 13, 2018 11:59 am
The guys building FIFI's(B-29 engines tell me Rotella T has the highest amount of zinc in the US.
So,for break in,I've been using that and a bottle of additive.
Kind of a belt and suspender approach.
CZLN6
Post #6 by CZLN6 » Tue Mar 13, 2018 12:12 pm
Howd F_M and all:
For use in an old engine a high detergent oil is my highest priority, but Rotella meets both high detergent and zinc additive requirements. Rotella is reasonably priced and easily available. When breaking in a new rebuild, with a new cam and lifters, a zinc additive is a good idea. When resurrecting an old engine you'll want to change oil and filter often for the first 1,000 miles or so, so price is a consideration. If I were maintaining a performance engine then I'd probably use a higher performance oil.
That's my two cents, for what it's worth.
StarDiero75
Post #7 by StarDiero75 » Tue Mar 13, 2018 3:33 pm
wsa111 wrote:Brad-Penn Racing oil 10W-30. I contains all the additives, but detergent for street driving that the VR1 does not have??
VR1 doesnt have detergents? Crap i gotta switch then
wsa111
FSP Moderator
Post #8 by wsa111 » Tue Mar 13, 2018 8:27 pm
CZLN6 wrote:Howd F_M and all:
Good point David, the Rotella oil is a bargain compared to the Brad-Penn.
The Brad-Penn has a little more zinc & phosphorus than the Rotella, but you will pay for it.
You can always add Lucas additive which has all the good stuff in it & you will be in the ballpark.
64 200 ranchero
Post #9 by 64 200 ranchero » Sun Mar 18, 2018 1:07 am
I use Lucas classic car oil, it was designed for use with a flat tappet cam. I like it because the oil doesn't think out at higher temperatures.
60 ford ranchero 200 tri power, modified c4 trans, performance ds2 distributor, msd 6, 3 stage retard, weber ict's, 8" rear end with spool, 3.40 gears, CI dual out header, Flowmaster, 90hp wet nitrous kit.
Users browsing this forum: No registered users and 15 guests
