66 falcon wagon
66falconwagon
66 falcon wagon
Post #1 by 66falconwagon » Fri Jul 27, 2018 10:43 pm
Will a C4 from a 65 mustang bolt up to the inline 6 in a 66 falcon wagon?
rbohm
Assistant Admin
Re: 66 falcon wagon
Post #2 by rbohm » Fri Jul 27, 2018 11:47 pm
if the C4 came from behind a small six it will.
64 falcon
66 mustang
05 grand marquis
transient nodes of thought
of invention
B RON CO
Re: 66 falcon wagon
Post #3 by B RON CO » Sat Jul 28, 2018 12:07 pm
Hi, X2. The early Ford six could have a large or small bellhousing, with a high mount starter. The V 8 could have a 5 or 6 bolt bellhousing with a low mount starter, which won't fit the 6 cylinder. The C 4 could be case fill or pan fill. The bellhousing comes off of C 4 trannies, so if you have the wrong bellhousing you can switch it. Get the Ford Falcon Performance Handbook to learn about bellhousing choices and get the most out of your Ford 6. Good luck
1966 Ford Mustang - 289 V8
chad
Re: 66 falcon wagon
Post #4 by chad » Sat Jul 28, 2018 5:14 pm
"... from a 65 mustang..."
is it a 6?
66falconwagon
Re: 66 falcon wagon
Post #5 by 66falconwagon » Thu Aug 09, 2018 11:55 pm
chad wrote:"... from a 65 mustang..."
is it a 6?
Yes
chad
Re: 66 falcon wagon
Post #6 by chad » Fri Aug 10, 2018 8:36 am
is it a 6?
Yes
Six to six then...
I understand later yrs have some advantages tho (better valve body?).
May B research that so when U swap U up grade simeltaniously - no need for drop later?
Re: 66 falcon wagon
Post #7 by bubba22349 » Fri Aug 10, 2018 9:58 am
One difference is that the Mustang C4’s used a floor shifter. So you might want to check the trans shifter arm (some will have both types) is able to be used with a column shifter if you need to keep that feature. Good luck :thumbup: :nod:
Users browsing this forum: No registered users and 31 guests
