Vacuum at the manifold and at the carb port are the same
except when the throttle is shut. When the throttle is shut, the carb port is effectively separated from the manifold. That is why you find no vacuum at the carb during idle conditions (unless your idle setting is high and your throttle plate is opened more than it should be). I recall having to set the throttle plate to ~ 1/8" open from the throttle bore when I was rebuilding it - but for simplicity, let's just say that the throttle is shut at idle. As soon as you open up the throttle, the vacuum at the carb port will go to what the vacuum at the manifold is. This is when you get your vacuum advance to kick in - when you are accelerating from low rpm.
There has been the big question out there (on the threads in this forum) as to where to hook in the vacuum line for the distributor - carb port or manifold? The way my car is set up - I have the distributor connected to the carb port so I get the additional advance when I accelerate and when I'm cruising. This set up works good for me. If I was to have the vac line connected to the manifold, I would have the additional advance from the vac advance canister
all of the time, so I might as well just bump up my initial advance to whatever the vac advance canister gives me and get rid of the vac advance all together - just go with straight initial and mech advance. My understanding of the vac advance is that it bridges the gap between idling conditions and when the mechanical advance begins to pick up - and mine tested out to do just that. Here are the numbers from my fiddling around:
Vacuum (Vacuum/advance): 0"/0 degrees, 5"/0 degrees, 8"/1, 9"/3, 10"/4.5, 11"/6, 12"/8.5, 13"/ 10 degrees - 10 degrees is the most my canister would put out.
Mechanical (rpm/advance): 1000/0 degrees, 1200/3 degrees, 1500/6, 1800/8, 1900/10, 2100/12 degrees - 12 degrees is the most my mechanical advance gave me.
Initial: 17 degrees @ 800 rpm (no mech or vac advance contributing)
Sorry, previously I said my initial timing was @ 14 degrees, but I have since set it to 17.
Total timing (rpm/advance): 1000/17 degrees, 1500/25 degrees, 2000/37, 2200/43 degrees - this is with the mech and vac adding into the initial. Now, the numbers don't quite add up - geeking out and interpolating between the above points to add initial + vac + mech at a set rpm. My disclaimer is I don't truely know the exact slope / peak of the vac curve and mech curve - and how they interact together completely when under load -
BUT (
Behold the
Underlying
Truth) those are the numbers that I measured. By the way, an adjustable timing light is great.
I tried the tuning by vacuum method and I couldn't get it to work. The vacuum on my manifold did not change a bit while adjusting the carb or while adjusting the timing - 16" is all I got.
Ludwig,
Here is a plot I found when trying to figure this all out. The left axis is vacuum in inches and the right axis is throttle position in percent full travel. The bottom is time. I have no idea of what car this is from, but it clearly shows the relationship between carb port vac and manifold vac.
Mind you, that some carbs (the early ones I believe) have a spark control valve at the carb which reduces the vacuum at the carb (i.e. it will only be 25% of manifold vacuum) so a more sensitive vac canister can be used on the distributor. My carb does not have that.
http://www.carbdford.com/tech/portedvsmanifoldvacuum.htm
Does this help?
ski
