I'm new to the forums and new to Fords so please bear with me. I have a 1980 Mercury Monarch 250/C4 pretty much all stock. As far as i know the car was owned by an old woman and only driven to church. It has 100k original miles and even the vinyl roof is perfect! It pretty much runs like brand new at idle. No blow by or leaks, not a twitch!
Now the bad and the ugly, the person i bought it from had it only for a short time and bought it as "cheap transportation". Well he didn't know anything about cars and had it serviced at a shop that knew even less than he did. When I bought the car he said that the shop had "adjusted" something to keep it from stalling.
well the car pinged like crazy so obviously the timing had been advanced.it is also missing the soleniod on the carb the drops the idle to keep it from dieseling when you turn it off. i bought it and took it home figuring it would be an easy fix and just needed all of the basic adjustments. Well the car is a vaccuum line nightmare and the emissions sticker is gone so I have no idea where any of them should go.
Now someone has been in there and rearranged stuff because some lines were just going in circles and both the distributor and EGR valve were not connected. Does anyone have any info on where to begin with this nightmare? I really like the car because it runs perfect but once you get it going all the misadjusted things keep it from running right.
It also has issues with turning off,it diesels if i turn it off in park and sometimes even if i leave it in gear. I have checked with ford dealers and bought every book i can find and there is no information at all on the vaccuum lines. if i could hook them all up where they need to go then i could try to see if all of the little vaccuum diaphragms work or not. It seems that there were very few of these cars with the 250 in 1980 because it is hard to even find this car listed with the 6 cylinder.
At this point it is just one huge mess on a car that would otherwise probably run perfect! OR maybe someone would have suggestions as to how i can remove all of the emissions items since that is not much of an issue where i live and date the system back to an older year's setup. I really would hate to junk a perfectly good vehicle but at this point it is not driveable and just isnt doing much for me aside from offering me parts for another car. I'm a GM guy and totally lost here. I appreciate any help you guys have to offer and sorry for the extra long post.
