Running a DUI on a fairly stock '66 200 cu in. It has a header, port divider, mild port job, Autolite spark plugs and a slightly used Pony Carb Autolite 1100. And it flippin' runs great!!!
The DUI is the best cure for Load-o-matic faulty SCV valve!
I couldn't find the used parts I needed for DS, so only a few bucks more I got the DUI as compared to what I would spend for new DS stuff plus a MSD-6. It installed in minutes; a single wire is all it took!
My ignition and stock induction is squared away. Installed a big block radiator. Need a little front end work, brakes are good & tires are fair, so everything's in working order. Now it depends on what happens next: Either Summit ships the Offy manifold I ordered a month and half ago or the 2.77 3-speed spits out a syncro and in goes a T-5.
Go for the DUI; you'll never have to worry about the ignition again.
