I'm currently working on my tri power set-up and I went with 3 C/W 740 carbs..
I've heard there is clearnece issues with the rear carb and the hood brace, but I dont know for sure.
I've been researching tri-carb set ups. My Offy has been back ordered for two months now. There's two different manifolds. The outer two carb bases have a smaller diameter than the center one. I don't think 3 RBS carbs will work. It depends on the bolt spacing.
RBS's are available in both the large and small base. I don't know which cars used the smaller RBS's but i have a pair of small base RBS's that came from a boat with a GM 4 cyl. Which would give rise to the theory of 4cyl Chevy 11's. By the way that little 4 cyl with 2 carbs in a boat was rated at 120 HP at the crank.
