I went out to start the Falcon this morning and the starter was clicking but the engine wouldn't turn over. I pulled the plugs and put a breaker bar on the crankshaft bolt but it wouldn't budge. I didn't have time to do anything else before I had to get to work.
It's been running great with lots of oil pressure (40+) and no signs that anything was going wrong.
I suppose the starter could be bound up in the ring gear even though it still makes a clicking noise??? That would be the easiest to check so I'll try that at lunch. Any other suggestions on easy things to check before I go tearing apart the engine? The main bearings are about 1-1/2 years old.
Engine and car specs are below...
