The six cylinder heads never crack unless they have been
a) repeat overheated or
b) run on low octane unleaded with a high compression ratio.
c) frozen in the winter (the front of the block tends to crack, not the head!)
d)The exhast manifolds tends to crack, but I've not seen cracks on the head
The HSC has its head bolts fully inclosed rocker cover. It is rather like the Aussie cross flow in that manner. On the 144/170/200/250 log heads, there is a huge support area of iron in that integrated manifold.
A very, very common failure point on cast iron Cleveland, Windsor and alloy V6 heads with the sled fulcrum rockers is the casting plug drains where the sand is removed from the water jacket. It is very common for cracks to apear during magnaflux or zyglo tests. In many instances, cracks are not terminal, but most prudent machinists biff them and get another set. Alloy can be repaired, but iron isn't nearly as easy to fix becasue the welding or plug process can propagate cracks. A good welder can fix iron heads if they are confident the cracks aren't major stuctural items.
