kukm66
I will start the process of having the port divider into my OZ head. The spring will be removed inside.
How many have successfully had it welded in without it coming loose?
Who here had holes drilled and tapped and screwed in the divider?
Was the divider a direct fit? As I understand it, the structure is slightly different inside the chamber dividing wall.
