Could've had a fire...
69Falcon
Post #1 by 69Falcon » Wed May 07, 2008 7:57 am
So yesterday I'm leaving work, heading to the grocery store, and I'm smelling gas. Pull over and pop the hood, and HOLY CRAP the 4" flexible hose between the hard line and the carb has split and its spewing gas directly onto the intake manifold, filling the valleys deep enough that it formed a pool and it is boiling!!!! :shock: :shock: :shock:
Luckily it wasn't landing on the exhaust manifold instead!!! I had some replacement hose in the trunk, so I put a new piece in and was on my way.
Chuck
Always thinking too much...
x21
Post #2 by x21 » Wed May 07, 2008 9:25 am
Maybe carrying a fire extinguisher might not be a bad idea :idea:
Glad nothing serious came of it though!
ludwig
Post #3 by ludwig » Wed May 07, 2008 9:55 am
Those 45 year old rubber lines just don't last, do they? I had to replace my rubber fuel line to the carb as well. I fear I will only get 20 years out of the new material.
Bort62
Post #4 by Bort62 » Wed May 07, 2008 9:55 am
Make sure the rubber line you are using is rated for fuel, and inspect regularly ;)
Scary...
rbohm
Assistant Admin
Post #5 by rbohm » Wed May 07, 2008 10:06 am
8) i know how you feel, i once had a fuel filter decide to spring a leak, all over my distributor.
64 falcon
66 mustang
05 grand marquis
transient nodes of thought
of invention
frogmn666
Post #6 by frogmn666 » Wed May 07, 2008 10:46 am
I bet the people at the grocery store appreciated you stinking up the store. It could have happened on the way to work and you would have pissed your co-workers off.
66 Fastback
Post #7 by 66 Fastback » Wed May 07, 2008 11:06 am
I've noticed that although I have more money to buy the parts for my car than I did 25 years ago I seem to have less time. I noticed a fuel smell the other day and my fuel line at the fuel pump is old and weeping. A couple of weeks ago, a heater hose let loose where it had been rubbing. The heater hoses are soft and need replacing too. With kids, and other house projects, 5 to 10 years can pass by pretty quick on some car maintenance items.
Doug
frogmn666
Post #8 by frogmn666 » Wed May 07, 2008 11:16 am
My `94 Dodge Ram still has the stock belt and hoses at over 124K.
66 Fastback
Post #9 by 66 Fastback » Wed May 07, 2008 11:23 am
Maybe I am wrong, but it seems some of the aftermarket hoses you buy now days do not seem to last as long whether they are heater hoses or fuel lines.
Doug
frogmn666
Post #10 by frogmn666 » Wed May 07, 2008 11:28 am
If they are made in China, would you expect anything better than that?
66 Mustang Coupe 3.3L 1100 stock carb 128K miles, attempting to convert to DSII/HEI
wallaka
Post #11 by wallaka » Wed May 07, 2008 12:27 pm
frogmn666 wrote:My `94 Dodge Ram still has the stock belt and hoses at over 124K.
It ain't the miles, it's the years!
Down to 29 cylinders!
2006 Porsche Cayman H6, 1968 Mercury Monterey big block (390), 1967 F-100 240, 1965 Mercury Comet 404 (200), 2009 Triumph Street Triple
frogmn666
Post #12 by frogmn666 » Wed May 07, 2008 1:00 pm
Do the math! :roll:
69.5Mav
Post #13 by 69.5Mav » Wed May 07, 2008 1:11 pm
I was working at a Texaco station in the Chicago land area in July 1977. A car pulls in the driveway and the driver gets out and opens the hood. I promptly notice two parallel streams of fluid pulsing 25 to 30 feet in the air. The driver walks over to me and asks " is it safe to drive home". Turns out, you guessed it, the fluid is gas. I tell him heck NO. Well He drives home anyway and returns the next day so I could replace his leaking fuel pump, on the hottest day of the year no less. I to this day have no idea how he got that car restarted the next morning with out getting incinerated.
Thirty plus years later I know what I should have done was taken his keys and refused to give them back unless the police told me to.
Could have been a Darwin Award winner.
wallaka
Post #14 by wallaka » Wed May 07, 2008 2:40 pm
frogmn666 wrote:Do the math! :roll:
EFI rated hose is much, much better than the junk that came on older cars. It's reinforced and a better grade of rubber to boot.
So I did the math, but remembered to put all the variables in :wink:
kukm66
Post #15 by kukm66 » Wed May 07, 2008 4:48 pm
Here in Phoenix, rubber lasts about 2-3 years before it starts to show fatigue and cracks. I regulary replace the rubber fuel lines as a preventitive measure.
1964 Falcon Futura Convertible
1964 Ranchero
69Falcon
Post #16 by 69Falcon » Wed May 07, 2008 7:58 pm
x21 wrote:Maybe carrying a fire extinguisher might not be a bad idea :idea:
Actually, I do carry a fire extinguisher for just such an occasion!
Chuck
Geezer 300
Post #17 by Geezer 300 » Wed May 07, 2008 10:38 pm
I remember in the "old days" they had see through red fuel lines, looked cool at the time 8)
77 Ford 300 500 Performer, Offy C, BBF 1.73 rockers, dual oil filters w/oil cooler, Jacobs ignition, 5 spd o/d tranny, 3.55 Dana 44, Pacesetter headers...more to come
2004 Mustang SVT Cobra convertible
Rinke
Re: Could've had a fire...
Post #18 by Rinke » Thu May 08, 2008 7:51 am
69Falcon wrote: filling the valleys deep enough that it formed a pool and it is boiling!!!! :shock: :shock: :shock:
I had the same thing when firing up for the first (and second) time except I didn't tighten the fuel to carb connection enough.
Here the fuel WAS dripping directly onto the hot manifold, but that was instantly vaporised. I don't know what's more dangerous. But I sure was glad I had a HUGE fire extinguisher at hand for the, just in case I forgot something, moments. :roll:
Rinke
64 Falcon Station Deluxe
3 on the tree
170
3.50:1 rear end
Been collecting dust & adding rust for 30 years
Goal: to keep it all working from okt 2008 till all eternity
Users browsing this forum: No registered users and 22 guests
