2018 Contributors:
distributor and fuel pump
60tudor
Post #1 by 60tudor » Sat Jun 14, 2008 12:32 pm
I was at the yard yesterday looklng for a few things and I came across some parts for the falcon. I took a distributor and coil from an 84 ltd with a v6, and I took a fuel pump from a 4.9 truck engine. Im pretty sure I can wire up the distributor but will the big block pump work on my 144. It looks the same but I didnt think about it until I was already out of the yard. Thanks for the help
Darrell
60tudor
Post #2 by 60tudor » Wed Jun 18, 2008 12:22 pm
So does nobody know, or just not care?
eeyore
Post #3 by eeyore » Wed Jun 18, 2008 1:09 pm
I don't know but I would epect that they are different. There is a sticky on this forum showing how to swap levers on a Carter pump, maybe that will work for you. But I'm not sure its worth the effort for a stock JY pump.
Dave
Bobscoupe
Post #4 by Bobscoupe » Wed Jun 18, 2008 1:53 pm
I don't think any of the parts will work on a 144 ci ford six.
Bob Sherrin
USAF, Retired
aka +68coupe+
CoupeBoy
Post #5 by CoupeBoy » Wed Jun 18, 2008 1:55 pm
I doubt that a '84 v6 distributor will work in a '60 144 i6, they are completely different engine designs (V versus Inline).
-ron
wallaka
Post #6 by wallaka » Wed Jun 18, 2008 3:04 pm
There is really no way that the V6 dizzy will work. Different length, different oil pump drive, and different seat diameter.
What WILL work is a TFI dizzy from a 2.3L with a transplanted reluctor from a 3.8 to get computer controlled ignition. But that's rather advanced.
http://fordsix.com/forum/viewtopic.php?t=38241
I also doubt that the fuel pump will work too.
Down to 29 cylinders!
2006 Porsche Cayman H6, 1968 Mercury Monterey big block (390), 1967 F-100 240, 1965 Mercury Comet 404 (200), 2009 Triumph Street Triple
Eric Rose
Post #7 by Eric Rose » Wed Jun 18, 2008 3:56 pm
Most junkyard fuel system parts I've ever gotten have been bad. The junkyards around here drain the fuel systems so all the rubber parts like diaphragms are usually dry-rotted.
Not too much of a big deal on the newer fuel-injected cars but on carburated cars with manual fuel pumps....
I got 350 heads on a 305 engine. I get 10 miles to the gallon, I ain't got no good intentions.
- Mike Cooley, aka the Stroker Ace.
LaGrasta
Post #8 by LaGrasta » Wed Jun 18, 2008 5:03 pm
what did you get these for? I hope you didn't pay very much. Neither are expensive as rebuilt units. As for the distributor, they almost never need rebuilt, only adjusted/tuned.
I don't know the answer to fit, but my guess would be absolutely not; different engine, different year, in fact entirely different era. :shock:
1963 1/2 Falcon 170/C4/8" (alt, a/c, Petronix/42v coil/8mm wires, 16" electric fan, electric fuel pump, Holley 1940, K&N Harley air filter, power dual m/c, 11" disc, 3" drop, Shelby drop, white tuck/roll, Moon steering wheel, '59 Caddy tail lights, fishtail exhaust tip, shaved trim, handles, cowl, fuel, dash, 4" radius trunk/door corners, power windows, 600w iPod system)
60tudor
Post #9 by 60tudor » Thu Jun 19, 2008 12:54 pm
I was confused about the tempo parts. I saw a couple at the yard but forgot about changing the ring in the distributor. If I get the 2.3 distributor can I take the reluctor from the 6 cylinder distributor?
wallaka
Post #10 by wallaka » Thu Jun 19, 2008 1:04 pm
60tudor wrote:I was confused about the tempo parts. I saw a couple at the yard but forgot about changing the ring in the distributor. If I get the 2.3 distributor can I take the reluctor from the 6 cylinder distributor?
Yes. The link I provided has a good writeup about that very thing.
Users browsing this forum: No registered users and 15 guests
