addo,
According to the following quote mraley was getting 176 with a stock bottom end, 264 cam, aussie head, holley 350 (built by wsa), and a dui. Seems easy enough.
Posted: Thu Mar 16, 2006 9:10 pm Post subject: D.U.I INSTALLED WITH DYNO RESULTS AND PICS
Well, I had the opportunity to test out the new D.U.I. Dizzy and let me say I am amazed at the change in performance.
First, It looks sharp. It will catch many an eye when you raise your hood. In my opinion This ranks as one of the best modifications I have done.
Installation was no problem. It is alot bigger as you can see from a stock dizzy, even bigger than the Duraspark II system that I was running.
For comparison, I ran two dyno's today. One before the install on the Duraspark II system, then later in the day with new D.U.I.
Before we go into the results, let me back track to last summer before I did the T-5 Swap. Below are the results from my last dyno that was done in July 2005. The temp. outside was in the 90's. My understanding is that dyno results will vary depending on humidity and temperature.
This is the 3rd run over a period of about a year. This run was made to see how many horses we gained at the rear wheels by adding an Aussie Head and a Holley 350. Previously we were running a 250 Head and a Holley-Weber Progressive 2 Barrel.
Before:
Max HorsePower 119.7 @ 5100
Max Torque 143.3 @ 3100
Top Speed 120 @ 5200 RPM
After
Max Horsepower 139.8 @ 5100
Max Torque 164.7 @ 3150
Didn't to top Speed this time....
Now....The following dyno is the before and after the install today. It was a much cooler day, about 75 and very low humidity.
Before..............
163.5 at 5100 RPM's at Rear Wheels
192.6 Max Torque at 3150
After
176.7 at 5170 RPM's at Rear Wheels
202.10 Max Torque at 3270
To sum it up...The new D.U.I. produced 13.20 more HP at the
