This is the second time an oil leak has developed at the left rear of the cylinder head to block area using the full roller 1.65 yella-terra rocker arms.
The oiling on this rocker arm design is thru the lifters via the pushrod to the rockers just like the small block fords & chevys.
The mounting plate for the rockers blocks the oil hole supply at the rear rocker shaft pedastal pad.
This leaves full oil line pressure to be present at the sealing area of the head gasket at the left rear of the engine.
I did a temporary fix by just installing the 1.6 rockers which use the oil supply for rocker arm oiling. Doing this lowered the full line oil pressure considerably at that sealing point. Now that stopped the seepage of oil.
Yes this requires a special pushrod.
I also can feel a slight loss of power & the idle is smoother cause the duration @ .050 is less with the 1.6 rocker.
The point is has anyone using the 1.65 yella-terra rockers had this oil leak problem???
The oil seeps down the left side of the engine bellhousing area & finally drips out the converter-flywheel area.
The correct fix which i will do in the future is to tap that oil supply orifice on the block with a 3/8-16 tap & install a set screw which will act as a plug to keep line oil pressure out of that area & not reach the headgasket seal area.
The fel-pro seeps worse than the previous victor head gasket.
Just letting the forum know of this problem & wondering if anyone else has mistaken this leak for the rear main oil seal.
Does anyone else have the leak problem with this setup????
Bill
Bill
