6=8":1z3zj3sg said:
My mustang had sat for 8 years before I got it but fires up and runs (now with some parts). anyhow it runs smoothly at high rpm but the minute i try to let it idle it dies and when I just get low in rpm's it gets choppy.
Points can sit for 8 years and not be affected short of moisture/contaminents getting under the cap. A carb can develop significant varnish in just a year of sitting.
The fact that it runs 'smooth' at higher rpm's suggests that your idle circuit is hosed (dirty, gummed, varnished, etc). If it indeed idles smooth (I mean real smooth no hesitation) at higher rpm, that would not suggest ignition. Ignition problems maybe less noticeable at higher rpm's but they won't go away completely.
From personal experience, after mine sat for several years, there was so much varnish(looked like tar) in the fuel sending unit, the engine wasn't getting any gas at all (swapped out a perfectly good fuel pump for nothing). As LG & FC suggest, I'd clean the carb and install a kit, plus flush the tank if you haven't already done so.
Edit: whoops...just saw the new tank comment
Edit2: above about 1000 rpm you're on the carb's main jet (a relatively fixed a/f ratio) below ~1000 rpm you're running on idle circuit...diff part of carb as TJ mentioned
PS I ended up also having a stuck valve and subsequently a bent push rod from sitting so long...it missed throughout the rpm range.
