Probably referring to the size(diameter) of the dish on the top of the piston.350kmileford":lnteibuw said:I don't quite understand the 2.320" diameter it is referring to. If those are just sealed power pistons, aren't they the same as the ones Mike sells? Or are they something different/special?
what is not right about them to not fit in the 200. i thought the 250 was the same with a longer stroke. the compression height is the same i believe.HARVEY LIGHT":395q4ryz said:In the falcon performance handbook David and Dennis outline the various options for pistons quite nicely. They state the 255's can be used in the 250 ci six for a compression increase but the pistons are not right for a 200. By the way thanks to them I've learned so much about our little sixes that this should be a must have boook for anyone looking to get more out of our favorite six from Ford. Harvey
