When I take my cam in to get it DFL coated I am getting the cam bearing journals coated.
Should I get the lifter lobes coated? I am not sure here.
One part of me says that there needs to be friction on the lobes to wear in the foot of the lifters to the cam lobe properly.
Another part of me says that this is a major friction spot in the engine and I should try and reduce friction here.
I will also be ordering my double roller timing chain set.
Seems like it would also be a good idea to get the timing gears DFL and oil shedder coated? Seems this would be another place to reduce friction.
DFL=Dry Film Lubricant.
Thanks for any info.
