Axle Roads
O K here's the problem: The engine starts out strong and sounds like a beast. After a short distance which varies from a few hundred yards to a few miles the engine starts to loose power and lacks high speed performance. It gets worse over time. When the problem occurs I have to give it more gas to maintain speed, which increases revs and makes a lot noise but doesn't translate into proportionate power at the wheels. Reducing speed increases engine performance slightly. If the problem occurs at a time where I can't easily reduce speed, such as on a highway, revs sound uncharacteristically high and I'm praying that I don't throw a rod, again.
Background: Ten years ago, I threw a rod going up a small hill and I had the engine rebuilt to stock specifications. I drove the engine very little for ten years. Two years ago I started working on this car and I found this site. The engine probably only has a few thousand miles on it so far. I've done a lot to the car in this time, but this problem remains. I now admit, I need help.
Known problems included: Cracked and loose exhaust manifold. Poor positive battery terminal cable. Leaky radiator. Fly wheel a quarter inch too forward. Noisy rear. Hot carburetor.
With the exception of the hot carburetor, I don't understand how any of these issues might be causing the problem described above, so I don't know where to go next.
I've done all the normal stuff. fluid changes, filters, and points, rotors, distributor cap.
I'm pretty good with the electrical stuff so I started troubleshooting here.
Upgrades: ignition uses TFI module or point (I can switch between them and problem occurs during modes) Blaster II coil. 7mm spiral core spark plug wires. Colder spark plugs, gapped at .040, indexed and pointed up. GM alternator swap. I'm running 15 Volts (w/ TFI), even when the problem occurs. I bypassed the carburetors de-icer.
I have long tube headers waiting to be installed, but I want to fix this problem first so I can feel the difference on the highway.
My experience is limited when it comes to carburetors, transmissions or internal engine parts.
It's a 67 mustang with original carburetor and distributor. I haven't done anything to the carburetor since I had the car inspected almost a year ago, except try different air/ fuel mixtures and then put it back.
After each upgrade I can feel an improvement at idle and while pulling out of the driveway, but my hopes of of fixing the big problem fade shortly there after. This is embarrassing when going up a hill at reduced speed and potentially dangerous when entering a highway on ramp. Can anyone point me in the right direction. What could cause this problem? Should I concentrate next on the carb, trans, headers or something else?
