I'm starting to wonder if my distributor is wearing out. It doesn't have any play when I grab the rotor but a few symptoms are leading me to believe this might be the case.
On the freeway, even with an electric fan, removed stat, new water pump, aluminum radiator and tranny cooler, the car runs hot after about 10 miles. Now and then, often under increased acceleration, the engine backfires through the carb. And while freeway cruising, I can feel the engine short-out for a moment, for just a split second.
I run a Petronix System 1 and feel confident it's working correctly. Any thoughts, can I test the dizzy some how?
